Hi, I was trying to use only Deezer Music in Automix mode.
The songs are playing fine on the deck but when adjusting the songs in automix editor I am not able to prelisten.
It's almost impossible to get nice transitions from one song to the next.
Is that the normal behavior?
geposted Wed 15 Apr 20 @ 2:04 pm
Don't think you can use Deezer tracks in automix because they don't cache.
geposted Wed 15 Apr 20 @ 5:10 pm
Keith is partly correct.
You will not be able to 'edit' the tracks for automix because they are not local on your system.
However you can use Deezer tracks in automix providing you don't want to edit them.
There is no work around other than downloading the tracks for a record pool elsewhere so you physically own the track.
geposted Wed 15 Apr 20 @ 5:17 pm
