hi everybody-
2 questions :
1) is it possible to create a transition time between shaders (like on the slideshow plugin), so we can control every when the shader changes ?
The auto-change shader is very general...
2) in shaders there is a "ALL" category. Is it possible to sort them (or any other shader folder) from a-z ? there are so many & it would help me so i can categorize them into folders etc.
thank you in advance for your answers
2 questions :
geposted Mon 20 Apr 20 @ 9:15 am
1 zVideoControl can change shaders timed to every, 1,2,4,8,16 or 32
2 seems a bit redundant, just move from (unsorted) into a folder.
geposted Mon 20 Apr 20 @ 9:36 am
