Topic: custom BPM deck
Hi friends :)
Is there a way, via script, to just get the BPM of the deck playing (example Deck A) and double it on the Deck B.
For example: Deck A is playing (85bpm), on deck B i press a custom button with a script that places the BPM on that deck B, the double as Deck A (170bpm).
Thank you !
geposted Wed 22 Apr 20 @ 5:50 pm
So you want to clone the same song with double BPM?
geposted Wed 22 Apr 20 @ 5:58 pm
Hi Kradcliffe
No, different songs. Just make the BPM of Deck B the double of deck A :)
geposted Wed 22 Apr 20 @ 5:59 pm
Not sure that's possible as the new track will have it's own BPM and you don't really want to overwrite it with an incorrect doubled BPM from the other deck.
geposted Wed 22 Apr 20 @ 6:04 pm
Not writing bpm Keith, just manipulating pitch
thing is with this it's only good with pitch range 100%
action_deck 1 ? deck 2 sync & deck 2 pitch & param_multiply 2 & param_cast & deck 2 pitch : deck 1 sync & deck 1 pitch & param_multiply 2 & param_cast & deck 1 pitch
there's probably a neater way but I don't fancy figuring it out now
geposted Wed 22 Apr 20 @ 6:38 pm
Setting pitch to 100% and then using match_bpm might be faster. (assuming both songs are in a similar bpm range)
geposted Wed 22 Apr 20 @ 6:42 pm
Hi locodog
Your solution, actually almost gives me the result that I was trying to explain. The thing is that for example, if i have a 80 bpm the other deck gets a bpm around 170 which is more than the double...any idea why it happens? (it happens with other songs with other bpm too)
Even though thank you all for taking the time to answer i really appreciated that :)
geposted Thu 23 Apr 20 @ 3:31 pm
pitch range at 100%?
geposted Thu 23 Apr 20 @ 3:51 pm
Sorry locodog, I forgot to place pitch range at 100% now it works perfectly! :)
Thanks for the heads up
geposted Thu 23 Apr 20 @ 5:22 pm
