When I try to point to a new folder to use for audio only -> slideshow, it just keeps point to the contents of the old folder? Any ideas. I need to change folders several times during a set. Thanks.
geposted Fri 24 Apr 20 @ 4:43 pm
Did you use the correct Slideshow entry to edit the path?
(There's one under Overlays and one under Video Source)
geposted Fri 24 Apr 20 @ 4:55 pm
Works fine for me
But WARNING : Slideshow appear twice in the effect list once as overlay once as video source
Make sure you are using the right configuration panel (effect gui) for the right effect
They are independant and can have different parameters
geposted Fri 24 Apr 20 @ 5:01 pm
Thanks for the replies. I believe I wasn't using the bottom one. Seems to work fine now. I left the slideshow options window open and changed to different BPM visual loop folders during the set and it worked fine.
geposted Mon 27 Apr 20 @ 12:32 am
