Topic: anyone having issues streaming to Livesets?
hi last week it was working but i did update virtual dj
but i click start broadcasting... it connects but its not streaming nore will it connect on there servers.. do you guys know if livesets server is down or maybe virtual dj since the latest update? not sure.. figure i ask you guys..
as its says its connected to broadcast but it wont play and it wont connect on there end to broadcast
i checked my firewall rebooted my dj comp and my router... still cant find the issue
maybe you guys know
or is it because i dont have my mc7000 on me? i loaned it to a friend .. so i just running straight no mixer with the virtual dj
geposted Sat 25 Apr 20 @ 3:41 am
ok i figured it out i had to remove the mc7000 it kept it stored in
but i went to get my mixer from my friends
but i still having volume issues... I cranked the master volume wide open the channel wide open they both in the red
streaming still quiet.. if i look at recording under recording the volume is low not even half way
i tried changing the zerodb setting to +100 and it doesnt inscrease.. where do you set the recording/streaming level to get very loud
geposted Sat 25 Apr 20 @ 4:19 am
