I have latest version of Virtual Dj, using NVII as controller wich includes mic input. All is well when live streaming, however my microphone sound is not coming out in the stream? I hear my voice on speakers while mixing but not on live stream. Any help please.
geposted Sat 25 Apr 20 @ 10:50 pm
The mic of on the NV is not part of the usb audio interface, and rather its routed in hardware on the controller directly to master output.
Hence the computer (and VirtualDJ) can not hear the microphone for broadcast or record.
To record/broadcast the microphone you need to make a record loopback.
Simply connect an audio cable from booth output of the NV to a line-in at your computer.
Then add a "Record" entry in VirtualDJ sound settings, equal to this line in
After that mic works for broadcast ;-)
See here : https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Sat 25 Apr 20 @ 11:25 pm
Thanks will try
geposted Sat 25 Apr 20 @ 11:37 pm
Hey Folks,
So I followed the instructions from @rune, the only problem I have now is when I add the record input in my sound settings and I go live broadcast the sound of my mix and voice in being recorded from my laptop's onboard recorder and not from the line in I used from the booth output?
Any tips?
Any tips?
geposted Tue 28 Apr 20 @ 12:00 am
