Hi, I have been trying for hours to map the effects strip on my Numark Pro 3 to the knobs on my old M-Audio Oxygen 8 V2.
I would like to be able to control the various parameters for each chosen effect individually.
I have little to no experience with midi mapping. Everything I have read or watched makes it look so simple I'm at a loss as to what I'm doing wrong. Is it just that my midi controller is so old?
Any help would be very gratefully received
geposted Sun 26 Apr 20 @ 4:08 pm
do you have 2 controller licenses?
if not that would be the issue.
kinda doubt you can get a licenses for the keyboard.
geposted Sun 26 Apr 20 @ 5:36 pm
Thank you for the post wickedmix, I hadn't even thought of that. I'll look into buying another licence in the near future.
geposted Sun 26 Apr 20 @ 7:59 pm
To use a device that's not natively supported (like a MIDI keyboard) you'll need to buy/rent the full Pro Infinity license.
geposted Sun 26 Apr 20 @ 8:28 pm
