Topic: weird bug with shaders
is anyone having issues with using shaders when scratching??
let me isolate the issue..
*only occurs when using shaders with video mode(not cover and other modes..i didnt really check camera)
*doesnt occur with all shaders...i cannot isolate it to any type of shaders.
*auto change and beatmove doesnt have any influence
*i am not sure if this is totally correct...but scratching without the fader...there seems to be no problems.
the problem exactly is that there are performance problems with the program glitching and not being able to keep up as normal..pops in audio...scratch sounding like it is missing elements etc.
it seems like the crossfader movements associated with scratching causes the problems.
i recently started using shaders...and there were no problems before i started..so its not that my laptop cannot handle the workload....maybe the vga card is another story...but as i said..the problem doesnt occur with covers.
im using 64 bit everything..machine,program,shaders.
i have tried the video crossfader on all options..same problem
geposted Mon 27 Apr 20 @ 2:25 am
i suppose no one else has this issue.....
geposted Tue 28 Apr 20 @ 5:18 pm
