Topic: Need your help please!
I'm using the latest and greatest VDJ 8, with a NVII controller. I've been broadcasting and streaming on FB lately and had no issues what so ever.
My only issue, is I'm trying to use a microphone which I connect to my NVII, I hear the sound through my speakers but my live broadcast does not capture my voice.
I did what someone suggested, I took my rca from my booth out in my NVII and connected it to my laptop in the microphone and headphone jack and added an input in VDJ to Record. This hasn't worked for me.
Any help please I really need to get my microphone going.
Thanks,
DJ JROCK
geposted Wed 29 Apr 20 @ 1:44 am
There’s an option in Settings under Record which you can set to make it record your microphone!
geposted Wed 29 Apr 20 @ 2:22 pm
No setting under record.!
geposted Wed 29 Apr 20 @ 11:36 pm
geposted Fri 01 May 20 @ 12:34 am
HutsyPRO InfinityMember since 2014
Ah - I was looking for this but for Numark NS6II.
My mic arrived today, I plugged it into Mic 1 slot, sorted out settings as described, ensured the hardware volume was up, and also just discovered the Mic button in the software to turn on but still no sound on Broadcast.
Can hear mic output from my speakers though.
Seems like the same problem as the OP but just different controller, so hopefully same solution is possible and appreciate any help!
geposted Fri 01 May 20 @ 9:23 pm
http://www.virtualdj.com/manuals/hardware/numark/ns6ii/advanced.html
NS6II Manual wrote :
Due to hardware limitations it's impossible to record the audio of the MIC inputs connected on the back of NS6II as their audio is routed directly on the master output of NS6II. If you wish to record your mics or use the unit to broadcast you'll have to use a second/different audio interface.
Unfortunately not possible on the NS6II
geposted Fri 01 May 20 @ 10:02 pm
can he not hardwire master 2 back to his laptop line in?
or even, preamp the mic upto line level and feed it in as a lineIn input
geposted Fri 01 May 20 @ 10:17 pm
Ok - there is no 'easy' way of doing this. ;-)
geposted Fri 01 May 20 @ 10:27 pm
Thanks guys! Appreciate the help :-)
Thanks for the above. I kinda get the concept but a step by step would be awesome if possible.
Could I go into line-in from the mic direct into laptop?
Cheers!
geposted Sat 02 May 20 @ 11:15 am
Sorry - by "Master 2" that would be Booth?
I'll give that a go!
geposted Sat 02 May 20 @ 12:16 pm
