Topic: mapper - DDJ-SB3 & microphone
id like to know if there are any good mappers for ddjsb3 and ..how can i get around useing a mic it only allows the use of ioutput thank you
geposted Wed 29 Apr 20 @ 5:20 pm
What's wrong with the built in mapping? You do know you can remap things using a copy of the built in mapping?
Please explain what you mean by "get around" using a mic. What are you trying to do?
The mic on the SB3 is not part of the usb audio driver, so its never heard by computer (nor VirtualDJ). And can not be used directly by any computer software
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsb3/layout/frontrear.html
I guess you want to broadcast or record the mic, since it works perfectly fine to speakers only.
To broadcast/record, you need to add a record loopback. Basically an audio cable from the master out of the mixer to a line-in at the computer.
Then add a "record" entry in VirtualDJ sound settings, equal to this line in
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
hello. please tell me where can I get virtual dj mapping for pioneer ddj sb3? thank you/
