try to toggle between 2 maps with a button, if i do it for device with short name like "phase" it ok, for the vortex wireless 2 ? not work at all.
geposted Thu 30 Apr 20 @ 12:23 am
you're missing the space after :
geposted Thu 30 Apr 20 @ 9:56 am
and have an extra space in first string "Vortex Wireless2 "
geposted Thu 30 Apr 20 @ 10:32 am
oh snap. :) thank you!
geposted Thu 30 Apr 20 @ 5:36 pm
ok update. it still doesnt work!
even this easy one dont call the map
controller_mapping "Vortex Wireless 2" "keycueplay"
but if i do controller_mapping "Vortex Wireless 2" "Ignore"
it will call ignore. my maps not!
geposted Fri 01 May 20 @ 12:36 am
and the script is find write. couse when i change manually to this page i see the button on, change to other page off.
but it doesnt change with the button click with that script
geposted Fri 01 May 20 @ 12:37 am
thank for help, please remove that post. found better way without change the mapping at all.
my idea was to find a way to deactive some function but i did it with new var.
geposted Fri 01 May 20 @ 12:53 am
