Topic: Kam Digi Two is it compatible?
Hi I've been using an LE version of VDJ for some years now with my Kam Digi Two controller with no issues. However after having to restore my laptop to factory conditions, on reinstalling the LE version it is asking for a serial number which I have long since lost.
So I am now wanting to buy the home plus version so I can get back to spinning some choons. But The Kam Digi Two is not in the list of controllers. I am aware that the Kam Digi Two is essentially the same controller as the Akiyama Quattro which is in the list of controllers. Was just hoping that someone can confirm that my controller will work with the software before I fork out the £99 for it. Thanks in Advance, Gareth.
geposted Thu 30 Apr 20 @ 11:22 am
The basic rule is: If there is an LE version for your controller, then VDJ supports your controller.
geposted Thu 30 Apr 20 @ 4:36 pm
