Hi all
I installed the latest standard build (5681) where the search_playlists function was expanded to search in playlists and Virtual Folders.
(Changelog build 5681: search_playlists to search for a song inside your playlists or virtual folders)
But when I perform a search (I made a custom button to do the action: search_playlists) I still only get a list of playlists the song is in, not the Virtual Folders it's in.
Am I missing out something?
geposted Thu 30 Apr 20 @ 10:01 pm
Are your virtual folders in the root? Otherwise vdj will not know where to find them
geposted Fri 01 May 20 @ 2:49 am
They are under Local Music
geposted Fri 01 May 20 @ 12:00 pm
I've moved my Virtual Folders (via Explorer) from 'Documents>Virtual DJ > Folders > Local Music' to 'Documents>Virtual DJ > Folders' and it's OK now (search_playlists result also shows me the Virtual Folder it's in to).
Thx for the solution Adion!
geposted Fri 01 May 20 @ 12:33 pm
