Quick question for the pioneer mappers. When you browse on the XZ or the CDJ the default mapping lists the tracks in the folder and it also displays the artwork which takes up 1/3 of the screen. Can you turn off the artwork view and utilize the display better to only list the folder?
geposted Fri 01 May 20 @ 1:14 pm
Unfortunately you cant change anything in the layout of the Pioneer screens. Not available from device firmware
geposted Fri 01 May 20 @ 1:24 pm
That is unfortunate. Thanks for the quick reply djdad.
geposted Fri 01 May 20 @ 3:47 pm
