Topic: red spot in hotcues
Dear all
since the last months, in every song i play, there is this red spot in the FIRST CUE POINT. obviously i have done something, i dont know, but i want this to be removed
IMPORTANT, as you see in the picture, for example in this certain song, there are only cues chosen for number 3 and number 5, but still the red spot is there in the "empty" cue1
anyone knows the solution?
geposted Fri 01 May 20 @ 3:54 pm
It’s the cue color. Can be changed and or removed in the POI editor.
geposted Fri 01 May 20 @ 4:09 pm
No dear friend, is not the cue color
as i mentioned above, there is NO CUE chosen for number 1. is empty!!! and this dot is in every song!! either the cue is empty or not empty
is frustrating
geposted Fri 01 May 20 @ 4:11 pm
Which version of VDJ?
Which operating system?
Does it disappear if you change skin?
geposted Fri 01 May 20 @ 4:13 pm
i have the latest version 8.4
i use a macbook pro
and yes i just notice that it disappear when i change skins
geposted Fri 01 May 20 @ 4:18 pm
Must be a bug (or something similar) in that skin. If your using the latest 2020 version (8.4). Then it’s highly recommended to use a skin designed for that version.
geposted Fri 01 May 20 @ 4:21 pm
thanks for your time bro
i will try a different skin
geposted Fri 01 May 20 @ 4:23 pm
