Forum: Addons
Topic: Denon DJ Prime 2 Screen - Page: 1
geposted Sun 03 May 20 @ 4:34 pm
is that a skin for vdj?
or is this the release of the screen and Jogwheel Artwork from the controller with vdj?
It’s for the controller.
Really?? It's the screen installer and the jogwheel installer. In other topics they say no. It's not released..
They also say that it will automatically download and install when you connect the controller.
If it doesn't then it's not available yet.
New updated version 2.0 for Prime 2 Screen skin.
  • Added Horizontal Wave view
  • Ability to hide Wave completely (larger Browser)
  • Added Beat Jump value (requires Build 6154 - currently as Early Access - and default mapping)
  • Added clock
  • Added Beats number on waves (setting)
  • Added BPM Edit panel (long press of SLIP - factory mapping)
  • Changed Sideview button (shows selected view)
  • FX 3rd Param display (default mapping)
  • Fixed Time and BPM values truncated on Mac
Will be available as Update in VirtualDJ Extensions soon, but you could also delete the zip file from /VirtualDJ/Skins folder and will be automatically download the latest update.
Thanks
When I Use this skin on my:
MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
2.3 GHz Dual-Core Intel Core i5
8 GB 2133 MHz LPDDR3
Intel Iris Plus Graphics 640 1536 MB
I have issues with this skin slowing the interface down terribly... the music plays fine.... even the waveforms lag terribly... when I deleted this skin, the Prime 2 worked as a regular controller without the functionality of the screen....
I use an official usb-c to usb 3.0 to connect my prime 2 to my MacBook...
is there something I'm doing wrong....
v8.5 b6106 is my VJ version
why is it that the denon prime 2 skin cant be uploaded and doesn't work , i have been trying for months to turn the skin into prime 2 can something be done please
The skin is for the Prime screen not your main computer screen.
Once the Prime is connected , the screen skin will be automatically downloaded, installed and shown on the Prime screen. Isnt this working for you ?
Hi, I'm using a MacBook M1, the screen doesn't show up on my Prime in computer mode. Is the downloaded skin not compatible? I see it in the VirtualDJ/Screen folder, but it isn't in my Graphical Interface... just the Default ones show.
Same happened to me do find a solution ??
  • Added clock
My denon prime 2 have a lot lags screen. Any solutions. Im have a macbook pro 2020
Hello, is possible zoom out the entire waveform in horizontal view? Or only a few beats? Thanksss
The jogwheel screens.
Can these not display the time elapsed and remaining??
Thanks in advance.
No, they can only display what they display now. It's a Denon firmware/SDK limitation.
That's a real shame.
All I get is album covers/artwork and the vast majority of my tracks don't have them as I don't have any need for them.
Is there anything I can do to display anything in the jogwheel displays other than covers/artwork or the colours VDJ allocates to tracks.
Or do I refer to the previous post? 🤔😊
I would like it, they will make a new cover... similar to the denon prime go "extended" version with horizontal waves etc.
95%
