Hello ... I have a pioneer sx3, and at the moment I am using virtual dj 8.4 ... and I am testing with the virtual program dj ... but I have a problem with the samplers because in the serato program it gives me the opportunity to have stronger sampler ... there in the serato program there is an AM button that can be changed .. whereas in virtual DJ when pressing samples you have to press hard to be heard ... and what can I change to have stronger samples even in virtual dj ...
and I want to buy virtual dj full license ... how much does the program cost .... and do all the buttons work for me ... especially the samples more strongly ..
geposted Tue 05 May 20 @ 10:11 am
You can turn off Velocity (determines how loud the Sample will play depending on how hard you press the Pad) . Read here.. https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/layout/pads/sampler.html
geposted Tue 05 May 20 @ 11:48 am
