Software: Virtual DJ 2020 (32 bit)
Controller: DDJ-200
I'm a bedroom DJ
Looking to toggle through the pads (hot cues, loop, loop roll, etc) with a button on my controller but for the life of me I can't figure out the script. Any help would be appreciated.
Controller: DDJ-200
I'm a bedroom DJ
geposted Fri 08 May 20 @ 3:47 pm
The basic action to select a PAd page is
So you can use...
If you want to cycle through some specific pages, you need to query current and then choose what happens.
E.g. cycle through Hotcues, Loop, Loop Rolls...
or ... cycle through Hotcues, Loop, Loop Rolls and Effects (as i can see from your pic)...
Now if you use the "Favorite" Pages, and you want to have a script to cycle though your 4 favorite ones, and always work no matter which ones are set as favorites, you can use ..
pad_page 'TheNameOfThePadsPage'
So you can use...
pad_page 'hotcues'to select the Hotcues page..
pad_page 'loop roll'to select the Loop Roll page.. etc
pad_page 'hotcues' ? pad_page 'loop' : pad_page 'loop' ? pad_page 'Loop Roll' : pad_page 'hotcues'
pad_page 'hotcues' ? pad_page 'loop' : pad_page 'loop' ? pad_page 'Loop Roll' : pad_page 'Loop Roll' ? pad_page 'effects' : pad_page 'hotcues'
pad_page_favorite 1 ? pad_page_favorite 2 : pad_page_favorite 2 ? pad_page_favorite 3 : pad_page_favorite 3 ? pad_page_favorite 4 : pad_page_favorite 1
geposted Fri 08 May 20 @ 5:32 pm
awesome thx!
geposted Fri 08 May 20 @ 6:29 pm
