All,
Today I'm having an issue- have set up hot cues as a saved loop- specific time in seconds- shows up and plays in POI editor but doesn't play or show up in waveform when I trigger the hot cue. Any thought here? haven't had this issue before
geposted Fri 08 May 20 @ 5:06 pm
Check POI Editor and see what you have as Cue under Point type. Perhaps Cue is set as Marker only or Invisible ?
geposted Fri 08 May 20 @ 5:44 pm
Set as Cue and Cue is there in POI editor and loop is there also. In regular waveform Cue is there but not loop
geposted Sat 09 May 20 @ 1:47 am
Can you post a screenshot showing POI Editor and the Saved lopp Poi which doesnt show up in skin wave ?
geposted Sat 09 May 20 @ 10:22 am
new to forums- how to share a screen shot?- tried copy and paste but no luck
RT
RT
geposted Sat 09 May 20 @ 3:36 pm
Upload to an image/file server and post the link here
geposted Sat 09 May 20 @ 8:43 pm
