Topic: Splitter not working?
I bought a y splitter for VDJ in order to try and play one deck out of the speakers and one deck in my headphones, however all I'm getting is one deck playing out the right speaker/left speaker and right speaker/left headphone rather than out of the speaker and headphones separately.
I've got the sound setting as 'Stereo to mono splitter' but it's still playing like that. What could be causing this?
geposted Mon 11 May 20 @ 2:50 pm
Sounds like you didn't get the right splitter then.
It should separate left and right to different output connections, but it sounds like it just splits the signal into 2 identical outputs.
geposted Mon 11 May 20 @ 2:54 pm
geposted Mon 11 May 20 @ 3:09 pm
It advertises itself as:
Professional Audio Splitter: UGREEN 2-Way Headphone Jack Adapter is meant to split audio from one source to two outputs and enable you to use two headphones or speakers simultaneously.
So presumably thats wrong and i need a splitter that treats the speakers and the headphones completely separately? All the ones i can see work the same way as the one i bought?
https://www.amazon.co.uk/UGREEN-Headphone-Splitters-Earphone-Smartphone-Black/dp/B07S5QFWCR/
geposted Mon 11 May 20 @ 3:11 pm
Search for DJ headphone splitters.
Better still, buy a DJ audio interface that has at least two stereo outputs.
geposted Mon 11 May 20 @ 4:13 pm
geposted Mon 11 May 20 @ 7:31 pm
