Topic: VIRTUAL DJ 2020 SKIN
How can i get the new 2020 skin so i can add my dj logo to it it seems i dont have it when i go to settings /default /edit skin its the older version i dont see the xml doucumenthow come i have the program @ the new version of virtual dj 2020 but not the xml doc?
mod: don't post in all caps, it's a great way to be ignored
geposted Tue 12 May 20 @ 8:46 pm
NicotuxHome userMember since 2014
That's because you edited old one when it was the default one already ^^
rename the folder "Default" to "Old"
go back to settings / interface and select "Default" skin then click "Edit this skin"
now the new default editable skin is new default skin
geposted Tue 12 May 20 @ 10:44 pm
