hi :) just bought my first controller - used traktor kontrol s2 mk1. connected it and updated most recent drivers
installed vdj 8 and started play. deck 2 works perfectly. when playing a song on deck 1, as long as i dont touch the controller everything is alright, as soon as i touch the controller (for example increasing tempo) the deck gets stuck, not playing anymore and doesnt react to any function. in the meantime deck 2 work perfectly.
(btw im using macpro mid 2012 with macos 10.12.6)
thank you :)
thank you :)
geposted Thu 14 May 20 @ 9:09 am
