my Brides like to use Spotify or Apple Music to build/edit their playlists.
how do i get those playlists into VDJ on the IDJ Pool service which i can download.
so the workflow here is i want to only use streaming services/pools to manage/perform music playlists.
if i could let the brides access my IDJ Pool playlist, or my VDJ playlist, that's fine.
if i need to spent like $10/mo for a music streaming service to integrate with VDJ, that' fine.
i don't even mine using Soundiiz playlist converter or something like that.
i just need collaborative playlists that i can play live.
geposted Sat 16 May 20 @ 11:54 pm
You're a home user, and you are doing weddings? Only Pro users are supposed to play live.
geposted Sun 17 May 20 @ 7:07 am
i haven't done any live events with VDJ.
i'm still in trial mode. seeing if it will meet my needs.
geposted Tue 02 Jun 20 @ 3:04 pm
What DJ software were you using previously then, for the brides you mentioned - and how were you incorporating their playlists?
There are plenty of conversion utils/sites that will take a playlist from e.g. Spotify and convert it to standard M3U, so you can use your own music.
There is also a VDJ util that can read & import artist/track info from a plain text file to a VDJ playlist.
geposted Tue 02 Jun 20 @ 3:21 pm
i've just been manually recreating Spotify playlists on Traktor.
where is that VDJ utility, and will it access iDJPool if i don't have the song in my library?
geposted Tue 02 Jun 20 @ 3:36 pm
https://www.virtualdj.com/plugins/index.html?addonid=80364
I don't know if it (or indeed anything) will make an iDJPool playlist for you.
geposted Tue 02 Jun 20 @ 3:56 pm
Thanks!
geposted Mon 31 Oct 22 @ 8:59 pm
Use the program Spotiflyer (Send playlist, and tracks here to download)..I will not link it here but I'm sure Dr. google can help you
geposted Tue 08 Nov 22 @ 4:54 pm
Using that would break the terms and conditions of the streaming services.
geposted Tue 08 Nov 22 @ 5:49 pm
...pants on fire:
Moderation You're replying to a 2 year old post. OP is probably long gone, but here WE are.
geposted Tue 08 Nov 22 @ 6:34 pm
I can not see VDJ on this picture. I found this Picture in better resolution by searching his name on Google. Why so much hate DJMBR01
geposted Tue 08 Nov 22 @ 6:54 pm
