I have a xone dx, I want to use as controller and to stream to a Shoutcast Server, the latter is not a problem, I know that, I was wondering if the below mappers will work with the lastest VDJ. If I buy a license, either monthly or infinity?
https://www.virtualdj.com/addons/14622/Allen___Heath_XONE_DX_Mapper.html
geposted Sun 17 May 20 @ 3:34 pm
Looks like it will work, some of it is written to the old script standard, most of which still works but some bits might tweaking but it's trivial to fix.
geposted Sun 17 May 20 @ 3:49 pm
One last question, If I buy the infinity or monthly plan and try out this mapper, and does not work, i know i can cancel the monthly plan, but can i get my money back for the inifinity plan?
geposted Wed 20 May 20 @ 12:40 pm
There is a free 30 day trial of pro when you first install that should be long enough for a test
geposted Wed 20 May 20 @ 2:44 pm
There are no refunds for software.
geposted Wed 20 May 20 @ 5:47 pm
EU law grants some return rights, like 14 day cooling off.
I think however you don't need a licence to test, I believe gear needing a def file still has the 15 minute test time, from what I remember.
*Edit Ah but you would need a licence to DL the mapping,
but that would give you a argument for "not fit for purpose"
I am not a lawyer. Nor speaking in an official capacity.
rambling aside, I'll stick with my original statement as; the midi of the device hasn't change, definition files as far as I've seen are backwards compatible and finally mapping is mostly backwards compatible but my require trivial changes.
geposted Wed 20 May 20 @ 5:59 pm
