Hi, I'm trying to mess about with VDJ and I notice that my master output and headphone audio are not synchronised and makes it distracting when trying to mix
The setup is as follows:
VirtualDJ (v8.4 b5681)
Outputs
Master: Built in option - chan 1 & 2 - 44.1k 11.6ms 2out
Headphones: USB Audio Device - chan 1 & 2 - 48.0k 10.7ms 2o/1i
Any help in resolving this would be gratefully received
Thanks
Outputs
Thanks
geposted Sun 17 May 20 @ 3:46 pm
2 sound cards often have this issue, not much can be done about it, dropping headphones to 44.1KHz might help [if you can] but a 4 out sound device is the real fix.
geposted Sun 17 May 20 @ 4:08 pm
Get yourself one of these:
https://www.numark.com/product/dj2go2-touch
It's not much more than a DJ audio interface would cost, and you've got yourself a controller too :-)
geposted Sun 17 May 20 @ 4:31 pm
I changed the output on my MacBook to my bluetooth speaker and it changed the master settings to 48.0k 10.7ms 2out but it still sounds off...
geposted Sun 17 May 20 @ 5:11 pm
Bluetooth will likely just make things worse. There's an inherent delay due to the wireless transmission.
geposted Sun 17 May 20 @ 5:24 pm
