Hi there,
I want to use VDJ for broadcasting purposes, i want to tweak the end result with stereo tool.
How can i load the DSP plugin in to VDJ, if i use a stand alone encoder with the DSP it does work, but the much needed metadata is not transmitted to the server.
Is there a possibility for a third party plugin to be used ?
geposted Tue 19 May 20 @ 6:19 am
You must use the VST Plugin...
geposted Tue 19 May 20 @ 1:40 pm
