Topic: DATABASE Won't Open!! :(
In playing with the camera stuff and with VDJ crashing it has not hosed my database to the point that when VDJ8 opens my stuff is gone. :( What's the easiest way to get it back .. and yes I did have it backed up.
geposted Sat 23 May 20 @ 7:55 pm
*WHEW* Rebooted the computer and it seems to have come back up but I am not going to be able to use the camera function reliably. :( The program locks up too often if things are not done a certain way. Oh well, it was a good idea.
if you can't access DB it's usually because a vdj process is still running in task manager. check there next time.
