Hi, when editing MORE files at the same time (in batch mode) the following phenomenon often occurs:
if in the fields MISCELLANEOUS entries, (see picture 01: 'Romantic paradise' vs. 'Romantic Paradise')
i.e. different spellings are available, these are NOT always displayed or offered for selection at the same time.
It is then (often ONLY) the entry of the FIRST title of the marked file block which is displayed and can be confirmed.
However, if there is text within this compilation, i.e. from position 2 and following, which is to be selected for ALL files and which is to be entered duplicated in ALL files, then it is not visible.
(see picture 02)
The only remedy (AT TIME) is to DRAW THIS "representative title" BEFORE the edit mark as a block, TO THE FIRST PLACE!
(see picture 03)
Then its entries appear for selection for ALL other files.
(see Figure 04)
Please change this so that a FULL selection of ALL entries is possible (for ALL FILES), so that the previous moving to the beginning can be avoided.
DJF*
(see picture 02)
(see picture 03)
(see Figure 04)
DJF*
geposted Wed 27 May 20 @ 10:09 pm
