Is the ability to move folders dynamically in the tree gone? Can't seem to perform the action anymore.
Using the order file inside the actual folder, but as you can imagine, that can be a PITA.
Lastly, one of my external drives does not appear to have an order file. Any ideas on how to remedy that?
As always, thanks in advance.
geposted Fri 29 May 20 @ 5:39 am
          There is a setting for locking the tree, maybe you enabled that in the past?
    geposted Fri 29 May 20 @ 6:25 am
          I will give it a look. Thanks.
    geposted Fri 29 May 20 @ 6:34 am
          That was it. Was never enabled before... Funky!
Thanks very much.
    Thanks very much.
geposted Fri 29 May 20 @ 6:36 am
