wanna create a simple visual (in a plugin gui)
<visual x="0" y="0" width="100" height="100">
<off shape="circle" color="black" color2="white" gradient="circular"/>
</visual>
<visual x="+100" y="+120" type="color" source="get_level_right" width="100" height="100"/>
problem: tooltip shows "GET_BEAT" and effectively flashing following beat
TESTED with different sources, types, ...
everything is flashing and having the tooltip GET_BEAT
what this problem ?
</visual>
what this problem ?
geposted Sat 30 May 20 @ 12:26 am
tested the exact same codes in main gui and there is no issue (and no tooltip)
geposted Sat 30 May 20 @ 1:02 am
After much more test it appears "<visual source=" are now mapped to get_beat whatever the skin is
geposted Sun 31 May 20 @ 2:30 pm
Did you set the version in the skin?
Edit: Or perhaps the main skin you have loaded is an old skin for v6/v7?
geposted Sun 31 May 20 @ 2:59 pm
Thanks, Yes, it is indeed related to version number interpretation change
- no version gives "get_beat" as well a 1.x ... (maybe very old behavior)
- 8.0 8.3 or 8.4 was enough until recent 2020
- 800 840 or 2020 now needed to get "source=" to be used all the time
version were set to 8.0 and 8.3 and 8.4
modifiing version number from 8.4 to 840 restored behavior
didn't saw recent default skin switched to version "2020"
geposted Sun 31 May 20 @ 3:35 pm
odd, "8" or "8.4" should still be sufficient
geposted Sun 31 May 20 @ 3:42 pm
