would be awesome if the mic could have audio effects
effects like delay, compression, also vocal transformer (you know the effect that you can use to change pitch, formant - turn male voice into female voice , robot voice etc.)
geposted Mon 01 Jun 20 @ 1:10 am
geposted Mon 01 Jun 20 @ 4:56 am
Also, the new skin from djtouchdan here has FX as well as three band EQ for the mic built right in to the GUI.
geposted Mon 01 Jun 20 @ 7:09 am
Adion wrote :
https://www.virtualdj.com/plugins/index.html?addonid=80618
strange, i cannot see this effect on my virtual DJ 64 or 32 bit, through the extensions feature.
and i cant download it directly from the website
geposted Mon 01 Jun 20 @ 6:07 pm
All [well, most] downloads are done in app these days, it's there in app, it's a padpage.
geposted Mon 01 Jun 20 @ 6:10 pm
It's not an Effect, it's a Pads page and you install it from within VirtualDJ Settings->Extensions.
Its an easy way to get some Effects on Mic , which is another slot for Effects same as Master, Decks, Sampler etc , unless of course you choose a skin offering dedicated buttons/knobs for this such as the above posted or Blocks.
geposted Mon 01 Jun 20 @ 6:12 pm
ahh ok , i got it now , thanks
i see now that this gives us access to the virtual DJ effects, same ones we have on the decks.
however this is missing some of the stuff i was asking for. such as vocal transformer in particular.
i have been thinking about this, and Autotune would be also an amazing feature , especially if doing karaoke (adjustable , of course, so that it could be subtle or strong)
think of the roland VT4. of course you could just buy the VT4, but having it in the software is always an advantage, and virtual DJ does everything , so maybe some day it could do this too :-)
geposted Mon 01 Jun 20 @ 8:37 pm
Nothing stopping you using a vst.
geposted Mon 01 Jun 20 @ 9:04 pm
Waves OVox is pretty good.
geposted Mon 01 Jun 20 @ 9:53 pm
true a VST would work
then again.... if an autotune /vocoder feature was in built in VDJ, you might be able to set it to set follow the key of the song which would be fun (if hit and miss)
geposted Thu 04 Jun 20 @ 6:52 pm
