I seem to have a problem with my custom buttons. I created one and that one comes back every time i start VDJ. (this is what i want) however when i create a new one (or more) they are not being kept by VDJ and i need to create it again and again when ever i start VDJ. is there a way to save them?
thanks in advance
thanks in advance
geposted Mon 01 Jun 20 @ 3:04 pm
custom buttons are saved in settings
As soon as settings are saved the custom button are (must be) saved too
you can force saving settings (if a problem with vdj exit) by using "save_config" as a custom button
(this will save other modifications in settings as well)
another thing to note is custom buttons are multi buttons (can have multiple functions by buttons)
geposted Mon 01 Jun 20 @ 3:19 pm
Nikotux, thanks I will try this and let you know if it worked
geposted Sat 06 Jun 20 @ 5:33 am
