After building 5541 in subsequent new versions, the sensitivity of the scratch became somewhat blurred. The mouse floats a little, if you smoothly scratch.
And on the controller I tested, the virtual needle behaves strangely:
- if you slowly move the jog back and forth (short jerks ), the sound is there
- if you pull the same very short amplitude back and forth, but the needle is faster, then the virtual needle seems to slip and does not cling completely.
geposted Wed 03 Jun 20 @ 1:30 pm
