Hello Everyone
Im trying to figure out why there is no 3412 mixer order option.
When I connect vdj to a supported midi mixer like the 900nxs2 it allows you to see on the software what you actually doing in the mixer and it’s great.
The only problem is when im in situation that I need to use the two right decks (5/6,7/8) as my 1+2 decks.
U can manage the sound card to do that but u still see on your screen the actions from the “mixer order” that marked (for example like u see in the picture, if i move deck 3/4 fader up - I will see it in the software)
Mixer order options are 1234 | 1324 | 3124
I need the 3412 option that missing.
Thanks
Thanks
geposted Fri 05 Jun 20 @ 11:32 am
geposted Fri 05 Jun 20 @ 11:33 am
Why can you not use the left 2 channels instead?
geposted Fri 05 Jun 20 @ 11:44 am
In most cases that’s what I’m doing..
Last week I played back 2 back and had to use the 2 right deck...
Before the corona I played in a club with a mixer that the left channel was broken 🤷♂️
So it’s not something of life and death but it will be nice to have this option
geposted Fri 05 Jun 20 @ 1:14 pm
