I used a program to convert my AVI MP4 VOBS music videos all to MKV.. well Virtual DJ cant find them.. so scanning for Same file name but different extension... is there a way to scan for same file names
and will there be a search.. if relocate cant find the file name.. it finds a Similar name
as that be a good option to add when you change file extensions to the better Video format of MVK
but ok ill try that in virtual dj thanks
geposted Tue 09 Jun 20 @ 5:33 pm
ok got it installed.. so far it hasn't popped up still cant do the relocate option
is there a section where I can leave a message to request an option in virtual DJ like some ideas how to improve the relocation missing file search?
like if file name is changed or if File Extensions have changed from AVI to MKV
geposted Tue 09 Jun 20 @ 5:50 pm
Requests/suggestion can be made here:
http://www.virtualdj.com/forums/18/Wishes_and_new_features.html
geposted Tue 09 Jun 20 @ 6:20 pm
ok great thank you... so far the issue hasn't popped up but I haven't tried much yet,,,
thanks for all the help so far (: most appreciative
geposted Tue 09 Jun 20 @ 9:36 pm
thanks again and I wrote some ideas.. plus a bug in vdj when moving folders in virtual dj of the same name
it doesn't allow you do it .. not how windows allows it virtual dj doesn't.. so I told them a bug in it be nice to have option write into save or just not give an error windows file copy doesn't give this error
geposted Wed 10 Jun 20 @ 1:52 am
