So I use a Bluetooth headset for sound and for my MIC it has worked with previous versions with no issues. However since two updates ago now anytime I turn on my Bluetooth headset all sound from all sources on my computer is stopped. If I turn off the headset it all comes back this makes it very hard to stream DJ and I am wondering if anyone knows how to fix it?
Also if I delete the MIC entry in audio settings I can hear sounds through my headset again just fine but as soon as I add MIC back it kills all sound.
geposted Sat 06 Jun 20 @ 8:36 pm
You haven't provided enough information. What headset is it (make and model)? What computer are you using (make and model)?
Most importantly, please post a pic of your VDJ audio config.
geposted Sun 07 Jun 20 @ 9:02 am
