From the last update VDJ don't save the settings what's the problem ? someone can help me with this I have a MacBook Pro
geposted Sun 07 Jun 20 @ 2:11 pm
What setting have you tried and is not saved ?
Usually it's a Permission issue, so right-click on /Documents/VirtualDJ folder (and/or the settings.xml file in there) and check if you have Write permissions
geposted Mon 08 Jun 20 @ 9:56 am
I have permissions for read and write the problem happen with the all settings and this problem started from the last update
geposted Wed 10 Jun 20 @ 2:09 pm
Applications->Utilities->system Preferences->Privacy tab
Is VirtualDJ in "Files and Folders" with checked (enabled) to access Documents Folder ?
geposted Wed 10 Jun 20 @ 4:33 pm
