Topic: American audio VMS4.1 software
joekodePRO SubscriberMember since 2012
Can I get the interface for this Controller. The ones i see is not working properly as per the original interface.
geposted Mon 08 Jun 20 @ 10:37 pm
Software? Interface? Do you mean the skin?
You don't have to use a particular skin with a controller. You can use any skin.
The default skin in the latest VDJ is very versatile and can be switched between various views.
geposted Tue 09 Jun 20 @ 7:21 am
