I'm trying to map a button on my controller to switch decks in 4-deck mode. I'm using a Musysic mu-midi17 controller which comes up as 'FactoriesF KTRL' and vdj8. In the custom mapping menu I can see the button press comes in as 'PFL'. I found that in the list, it was set to select. I set it to invert_deck and save. There is no effect when I press the button. I tried the BPM button as well and while it no longer functioned as a beat tap it also did not swap decks. I had the same problems trying to map midi pads to toggle effects with no luck. Advice?...
geposted Tue 09 Jun 20 @ 3:33 am
So any VDJ action to any of the controller's keys hasnt worked ?
E.g. PFL assigned as .. loop , works ?
geposted Tue 09 Jun 20 @ 11:32 am
