Hello dear plugin producers.
I've got a question.
I have a lot of very good effects, unfortunately as a 32bit and a couple even from the 7 version.
I have raised this topic quite often in the Wishes Forum. That you can actually also support 32bit plugins in a 64bit version, for the purpose of up-compatibility.
But this falls on the deaf ears of the programmers.
No matter, there is a reason that they do not want it, and instead prefer to continue developing 2 programs ;-)
Now I have already written to a couple of the developers of the older plugins as to whether they could convert their plugins as 64bit. But don't get an answer from most :-(
Maybe they're not active here anymore.
Now I try to find someone else.
And just ask if there is someone who could rewrite older plugins in 64bit?
There are of course a couple more.
Of course I would like to pay for it because I know that it costs work ....
Or the other question would be.
What actually needs to be changed on a plugin to make it a 64bit?
The functions are the same, so there is something different there that needs to be changed in code ...
I would do it myself if I knew what the difference was.
Would be very grateful.
Greetings Dani
Greetings Dani
geposted Thu 11 Jun 20 @ 9:24 pm
Is there any particular reason that you need to run the 64 bit version of VDJ?
I mean, if you have so many 32 bit plugins that you want to use, why not run the 32 bit VDJ?
geposted Thu 11 Jun 20 @ 9:54 pm
Some V5 Audio plugins have source code it's a start point
Q: What actually needs to be changed on a plugin to make it a 64bit?
A: Nothing but all the call to 64 libraries for simple ones
Everything but the calls to VDJ API for complex ones ( i.e.: DX9 -> DX11)
Anything in between for most of the others
but everything have to be done from code :(
as the final generated cpu code is not the same Arch
Q: Maybe they're not active here anymore.
A: Yes, many are not active here anymore or don't care anymore of VDJ
Those old plugins are very outdated, not sounding any good, and there are plenty of modern native effects that does the job much better ;-)
geposted Thu 11 Jun 20 @ 10:46 pm
That's right for audio plugins, and many VST can help
but video plugins and transitions are most 32bit only and no modern or native or port (yet?) for them
geposted Thu 11 Jun 20 @ 11:09 pm
No actually there is no reason so far, the 32bit runs stable as well.
But it could be that at some point the 32bit will no longer exist, it will no longer be developed.
Or no longer runs under Win 10 ..
Can be ;-)
geposted Thu 11 Jun 20 @ 11:32 pm
Well, that's exactly my question.
And my problem.
I don't know how to change a code.
As I said, the functions are ok, I don't think I have to change anything.
Only the plugins don't run at 64bit ;-)
geposted Thu 11 Jun 20 @ 11:36 pm
Well, that may be .. And right.
But I also have many that sound very good.
And you can use it as a live performance.
Whichever I do.
I'll take 3 small examples: The 3 Mach 3 effects of Deun Deun ;-)
These are old, but I love them ;-)
geposted Thu 11 Jun 20 @ 11:39 pm
So far I have answered my reasons and your counter questions, thank you dear friends and colleagues.
If any of you can help me more, it would even be good if someone spoke German.
In certain things it is always difficult to understand and translate everything ;-)
Would like to continue using this pair of FX, even if 32bit may no longer exist ;-)
geposted Thu 11 Jun 20 @ 11:43 pm
Greetings Dani
Greetings Dani
Hi there, I know it's an old thread, but I have been for quite a long time looking for a way to still use a VST 32bit on the the new Virtual Dj 64bit version.
Here is the answer: jBridge
https://jstuff.wordpress.com/
Is so simple, really. Insall it, just leave all the default settings/check boxes.
Then, in my case I was able to just select the .dll file of the VST I needed in 64bit.
Last step you just select the folder where you want to have the new .dll file saved.
AND THAT'S IT! :)
I have just tested it, and it works :D
I was to delight to discover it (one week ago). Shame I didn't find it earlier.
geposted Sun 30 Jan 22 @ 6:29 pm
