Hey everyone I have just purchased a denon prime 2 controller. Is there anyway of using virtual Dj on it or at least getting my playlist on to it?
Thanks
Robert
Thanks
Robert
geposted Fri 12 Jun 20 @ 11:18 pm
Native support is coming soon:
http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
geposted Sat 13 Jun 20 @ 12:49 am
If you would like to have your VDJ virtual folders and filter folders on the Prime 2 (as crates) for standalone use, it's quite easy to do.
Unfortunately Denon don't support VDJ in their Engine Prime software (so no cue point or loop data from VDJ) but getting VDJ folders in to EP (to copy them to the P2) is possible:
Are you planning on putting a drive inside?
There was a recent post on the Denon forum explaining how to do it. CLICK ME.
geposted Sat 13 Jun 20 @ 6:50 am
Thanks for the responses guys. How to I do the m3u concert thing from the side list? I can’t seem to find it
geposted Fri 07 Aug 20 @ 4:13 pm
I’ve put a drive in my prime 2. Not bothered about the cues etc just wanted my playlist copied over
geposted Fri 07 Aug 20 @ 4:15 pm
Hello.
Can someone provide me some information about volume faders of prime 2 if they move also software faders in VDJ, because I was planning to play videos with this controller?
geposted Fri 07 Aug 20 @ 5:02 pm
Yes it can be used to control VDJ.
geposted Fri 07 Aug 20 @ 5:19 pm
