groovindj wrote :
In 2019 Atomix "banned" certain old Denon ASIO drivers from use in VDJ because of problems caused by those drivers. It should be possible though to use WASAPI instead.
See here
mrdjal wrote :
the new versions of VDJ do not seem to like the older ASIO
See here
Thanks GroovinDJ
I think Windows 10 updates is also an issue, the controllers work fine until i updated windows 10, only because my video card update needed something in windows updated
geposted Wed 23 Jun 21 @ 12:32 am
Hi guys my vdj 8 won’t launch on my MacBook Pro 2012 running Catalina 10.15.7 when I double click the icon nothing happens and nothing appears in task manager
geposted Sun 14 Nov 21 @ 5:13 pm
Try to rename the settings.xml file in /documents/virtualdj folder and then open VDJ again.
geposted Mon 15 Nov 21 @ 12:23 pm
Usually caused by a botched instal process for one reason or another - disk was full for me (see the Log Report in the VDJ folder) but downloading again from https://www.virtualdj.com/download/index.html and successfully installing will fix this issue.
geposted Thu 20 Oct 22 @ 2:23 pm
