Hi - the update has broken some of my keyboard mappings.
Two things are going on...
1 - Half of my keyboard shortcuts to jump to specific folders don't work, even though the addressing is accurate and the syntax is identical to working shortcuts. I understand that it might be caused by key conflicts, but there was no issue until I updated to 2021.
eg.
SHIFT-D
browser_gotofolder "Local Music/iTunes/VBDJ/DJ Disco"
doesn't work
SHIFT V
browser_gotofolder "Local Music/iTunes/VBDJ/DJ Faves VB"
DOES work.
2 - It seems most of the mappings that don't work when the Song List is in focus, DO work when the Folders List is in focus
Anyone else having these issues? Any thoughts on solving this?
eg.
SHIFT-D
doesn't work
SHIFT V
DOES work.
geposted Sat 20 Jun 20 @ 6:33 am
this might be due to the setting browserSearchByFirstLetter having been reset to Yes. put it back to No and you should be all good.
(there was a small bug in the first 2021 build that caused some setting to reset when upgrading, that has been fixed since)
geposted Sat 20 Jun 20 @ 7:02 am
Goddam... genius.
Thanks.
Thanks.
geposted Sat 20 Jun 20 @ 11:41 am
