Is it a correct assumption that the GPU on the Nvidia Quadro M620 graphics card isn't fast/new/good enough to be used as GPU in the new math engine?
From google:
NVIDIA Quadro M620. The 28nm NVIDIA Quadro M620 is a mid-range DirectX 12 (FL 11_0) and OpenGL 4.5-compatible graphics card for mobile workstations. It is a 1st generation Maxwell-based GPU built on the GM107 architecture with 512 of the 640 shader cores activated.Apr 21, 2017
DirectX: DirectX 12 (FL 11_0), Shader 5.0
Architecture: Maxwell
Memory Type: GDDR5
From google:
Memory Type: GDDR5
geposted Sat 20 Jun 20 @ 8:52 am
... since I can't get VDJ to use it even if I tell Windows it should, I'll assume it's correct (or look stupid when I tell people :) )
geposted Sat 20 Jun 20 @ 11:01 am
