Topic: iTunes Playlist No Permission?
Hello,
I can see the iTunes folder and the music and can play music from the iTunes folder, but the playlists are not working. When I open the iTunes playlist all the songs have a red slash through them and you can not play any of the songs from the playlists. I checked the permissions in iTunes and everything seems fine and the share for XML is selected. It would be much easier if I can access iTunes playlists to find songs---can you please help with this? Tx
geposted Sat 20 Jun 20 @ 11:23 am
Is this solved?
