The STEMS FX seems to also be active when turned off
So if you select it in an effect slot and just turn the knobs the STEMS separation kicks in, even if you haven't turned on yet
That's a bit of a strange behavior compared to the regular effects you select and use in the effect slots
geposted Sun 21 Jun 20 @ 9:17 am
Hi
I noticed this on the Hercules Inpulse 300 last night. Same issue, the dedicated FX On/Off button did not trigger the FX and the two dials (which on the 300 are allocated to vocal and instuments) are active regardless.
I am unsure if this can be adjusted in mapping as I would have thought the button would turn on/off regardless of the FX selected?
What controller are you using?
geposted Tue 23 Jun 20 @ 10:59 am
