I can turn the shader effect on and off via effect_active 1 'shader' on
is there also a way to change which shader is selected?I would like to be able to change the shader via a mapped button
geposted Sun 21 Jun 20 @ 12:39 pm
effect_string 'shader' 2 +1
geposted Sun 21 Jun 20 @ 2:07 pm
Hi Locodog, that did not work for the shader.... is it supposed to rotate to the next shader?
geposted Sun 21 Jun 20 @ 4:27 pm
