Topic: Virtual DJ 2021 Wont Install
I have a 64 bit Window's 10 laptop and it won't update and install the latest version of Virtual DJ 2021. During the install it says, "The specified account already exists". My Virtual DJ is still on 2020 not the latest version.
geposted Mon 22 Jun 20 @ 10:23 pm
If you look up that message in Google, a solution may present itself.
geposted Mon 22 Jun 20 @ 10:27 pm
geposted Mon 22 Jun 20 @ 11:18 pm
This is happening to me too, it happened after i tried deleting VDJ's files manually. I wanted to completely remove and reinstall VDJ because the 2021 update messed up 'effect_select'. Now im also stuck with this install error, "The specified account already exists". Im considering reinstalling windows completely :/ i would guess the error is from a certain license file or registry key.
UPDATE: The windows troubleshooter fixed it for me https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
geposted Sat 27 Jun 20 @ 4:42 am
Uninstall virtual dj 2020 and install the virtual dj 2021. It will work.
geposted Fri 31 Jul 20 @ 4:44 am
Can virtual dj 2021 install in wisdoms 7?
geposted Fri 31 Jul 20 @ 12:34 pm
No. You must use Wisdoms 10 64 bit.
geposted Fri 31 Jul 20 @ 12:42 pm
Hello amigo.
Use revo uninstaller to remove vdj propely, if you have your playlists, Hoitcue etc i suggest first you save them apart.
try to use ccleaner to finish to remove any trace of vdj in the windows registry.
normally it's going to work.
geposted Fri 31 Jul 20 @ 4:24 pm
emodahHome userMember since 2016
Virtual dj won't install on windows 7, 8, and 8.1
geposted Mon 11 Jan 21 @ 6:53 pm
You need Windows 10 64-bit for VirtualDJ 2021
geposted Mon 11 Jan 21 @ 7:28 pm
don't let me install virtual dj on mcbook pro
geposted Mon 23 Aug 21 @ 7:48 pm
