Topic: Denon MCX8000
Hello friends,
I was thinking about getting a Denon MCX8000 controller and wondered how well it worked with VDJ? Do you like the MCX8000 ? I'm just a small town DJ who uses a simple 4 channel controller and while is getting bad sound out of that controller. Its going bad most likely. So I thought I would upgrade maybe.
Thoughts?
Thanks
Captain Ron
geposted Tue 23 Jun 20 @ 7:19 pm
I have one and cant recommend it highly enough, it's a fantastic bit of kit. Everything is placed in just the right place and works really nice and smooth.
The biggest advantage is you can use 2 decks with usb sticks and 2 with the pc/mac. I love it.
Only downsides are the aysemetric transport controls and the physical size, not friendly for small booths.
Buy one, it's great!
Do you get all the controls using vdj for mixing etc ? I’m New to the mixing stuff.
Yes, it's probably one of the best VDJ controllers out there. And having the switchable standalone backup is the icing on the cake.
!00% recommend it.
any cool tips setting it up or using it I should try?
So I installed new drivers etc. I only get 1 of the 3 built-in effects? How do I get the built in effects ?
ahhh. ok.. I should have known that. sorry..
Thank you
