Hellllo people on FIRE!
Every single time... I have to go there and touch it to be ab'le to have some High end Mid...
Macbook Pro 2019 16"
Rane Seventy-Two
Rane Twelve
Last Update
BTW... Seventy-Two keep crashing after 30-45 mins...
Great job on the Soft 😎
Rane Seventy-Two
Rane Twelve
Last Update
geposted Wed 24 Jun 20 @ 3:07 am
That setting (headphone tone) is controlled by Rane firmware (hardware operation)
VirtualDJ can't control it, nor it has something to do with it.
geposted Wed 24 Jun 20 @ 9:05 am
Well... Why didn't I have this problem before the last version (2021)?
geposted Wed 24 Jun 20 @ 1:15 pm
Are you using factory default mapper ? Or a custom one ?
geposted Wed 24 Jun 20 @ 4:03 pm
Default mapper...
I reset all VDJ settings this morning. Issue solved!
This is my biggest issue: https://www.virtualdj.com/forums/235764/VirtualDJ_Technical_Support/My_mixer_always_disconnects.html
geposted Wed 24 Jun 20 @ 4:14 pm
I have the same issue since 2021. i have to set up the headphone at each session
geposted Wed 02 Sep 20 @ 10:53 am
